My car has clocked 98000+ and is totally driven on petrol. Performs very good Mashallah.I try my level best to keep it in perfect running condition. My cousin is having a 2006 Mehran and he was like your Mehran is so old i can beat you on CNG. We had a drag race and i smoked him so bad he got pissed.
After purchasing this car i did some maintenance work.
Changed engine oil. I use Havoline 20-50.It's red in color and so far the best oil which is made in Pakistan.
Changed oil filter. My bad i forgot to buy the oil filter of my choice which is Leppon so had to install guard oil filter.
Changed gear oil. Caltex gear oil.So far the best local made oil.
Changed the air filter. Was of good quality can't remember the brand but was a imported one.
Checked spark plugs and they were in mint condition. Double tip plugs they were.
Used Abro fuel cleaner and it did the job pretty well.White smoke came out of exhaust and within few days vanished.
After 1000 kilometers.
Bought engine flush.
Changed engine oil.
This time used Leppn oil filter.
Used radiator flush.And will later add coolant after flushing.
So i try my level best to make it perform well.Today at service station i noticed the distributor cap is set in the center.In which direction should i turn it to get more performance?Here is a picture of the distributor to make it easy for you guys.
