AOA and Ramadan kareem.
As the topic says i am willing to perform a radiator flush. Don't want to go to ustaads or those looters at dealerships. I have a rough idea about what to do. I am following the method told by Xulfiqar sir. Also found a thread about this
Which way should i go, imo the method by xulfiqar bhai seems good which involves removing the old coolant and adding a solution of citric acid, again removing that and topping off with new coolant.
Thing i want to know is should i pour the entire coolant into the radiator and reservoir ? I will be adding toyota long life coolant which i believe is already diluted. Only confusion is here.
Is there anything else i should we aware of, i will be thankful if someone points it out.
