Hello all,
I have visited this interesting forum countless times but this is my first post. I need your help in identifying this leaking part in my corolla 2015 (1zrfe- 11th generation). I discovered this leak while I was changing the transmission fluid. It is on the left side. Please see the attached picture. The leak is encircled in yellow. Any idea how to fix this leak?
Thank you.
Shock absorber is leaked.
Also control arm bush looks weak and rotor face is wobbly too.
Thank you! That's correct! This will have to be replaced. Any idea what is the part encircled? I have pushed it in its joint and the leak appears to have stopped.
That is abs wire. It has nothing to do with leak. The leak is coming from shock and falling on abs wire rubber.So you just need to replace shock to get rid of this messy oil.
Thank you brother. Will do that.
