Assalam O Alaikum Everyone Need HelpRecently i bought Corolla Xli 2009 1 lac 25 thousand drivenI am facing the following issues When i turn on Ac car gets heated and had some missing problem i did tunning changed engine oil and also checked all pipes of radiator and installed new thermostate for heating problem but still it gets heated and lastly some thing strange happened to my odo meter even in off position it showing the gauges
Clean ur radiator.And check cooling and condenser fans.For odo meter issue disconnect battery terminals for 30 minutes then connect it again.I also experienced this in same year corolla gli
Thankyou so much for the reply, but i have checked it by mechanic and he says i should change the bead gasket
U can check urself.If u see oil and water mixing in the radiator then it's head gasket.Other gasket is fine.
