.Clean throttle body.
.Get oxygen sensor checked, replace if needed
.Get spark plugs checked. Replace if worn out with original iridium tipped.
.Get fuel filter and fuel injectors inspected
.Get catalytic converter cleaned from a pro if needed, NEVER with acid though !
.Use 0w20 to max 5w30 full synthetic API SN engine oil
You can also try pouring liqui moly fuel system cleaner additive and liqui moly fuel injectors cleaner.
They're poured in full fuel tank.
