Assalam-u-Alaikum !
I am new to PakWheels.
I Don't have enough technical knowledge about the cars and was wondering if you guyz can share your opinions and suggestions before I see a Mechanic.
I have Suzuki Baleno 2004 (perhaps its the Sports version but i am not sure). I am facing some problems since last couple of months but keep ignoring given that I have a very limited usage of it. Let me try to explain but excuse me if i'm unable to use the appropriate terms.
Low pick - I need to give enough race in 1st and 2nd gear to accelerate. The problem gets worsen with A/C on. Sometimes the car gets turn-off with a backfire and minor jerk.
The indication for RPM doesn't stick to 1000 RPM (which i believe is the standard) in the idle state. It comes below 1000 mark and settle around 800.
I would like to add here that I've changed the coils and accompanying coil wires few months ago so I believe that it not causing this problem.
I would appreciate your help and suggestions.
