@Hassan1991 sure i will replace the transistor, capacitor plug this p08 if it acts up i will ping you, although can you tell me about this SST chip are these only one time programmable? finding a basemap and getting that chip i hear you although are these chips available in the local market or from where we can get them?
p.s: the other p08 i have i would want to have it socketed for hondata i will start working on this after eid holidays very recently i replaced the engine assembly and i was exhausted with the time i had to give to it when i got this car both engine and car parts weren't in very good shape i was driving on higher rpms and the crank started making sound and i decided to replace the whole engine assembly i didn't started looking in that manner but i think finding just the crank would have been harder anyways this engine i found seems hasn't ran much i haven't done a compression test yet though. Engine is putin and running great still there is some work left like throttle/tp sensor is acting up, i have air-intake upgrade a portion of custom pipe needs to be made for it, and i want to putin a front sway bar so this will give me sometime to work on ecu stuff that's it i guess any other car or engine parts which needed replacement is done new rims/tires xxr/rapid are installed as well which can be driven fast not that stance vibe it is lowered but before it had 17' super chrome rims they were too heavy and big for EG.
I don't drive this car much its only driven like 300kms after the new engine assembly but i would like to have things in good shape, recently i was done with piping and exhaust upgrade and i could see even the fuel/air ratio was not being handled correctly and that hurt me.
@supraman2jz sure bro as soon as i have the hardware that is the plan.
