first of all OBD II, meaning, LOTS OF SENSORS, computerized timing, almost maintenance free. Tune up would require an air filter / spark plugs change only.. and the timing belt would be changed at 100K intervals.. F8B is a simple engine, every thing is mechanical, other than the temperature sensor, there is only one sensor in the engine and that is for the oil pump. One is for the generator / battery, one thermostat switch for the radiator.. and lol thats it
You can advance / retard it as you wish and stuff.
of course the F8c/d f10d, would be using internals made of better, light weight materials, stronger and would be higher revving, the heads would be ported much much better, the intake manifold / exhaust system would be optimized for a really good flow.. etc etc.. Instead of the vacuum switches and distributor found in the F8B engines, you'd be dealing with things like IAC, TPS, MAP, MAF, O2U, O2D and other boring stuff.
you can google, but to be honest, I tried for 1 min and couldn't find anything.. I will see and if I get time then I'll look into that.. If you know about engines, you should give the Suri sahab
visit and see for yourself, check the prices have a look around..
In 5 lacs you can build two Mehrans yourself and with better quality materials
