Hi all. First post here. I'm trying to get some information as to what engine oil and gear oil I should use. I bought an exi pros 2004 in white. Car has done 104k kms, previous owner had CNG, ive completely removed the damned thing and now running on a mixture (30/70 Hi-ocatane and normal). I dont know what engine oil and gear oil the previous owner used. Ive been reading reviews on Liqui Moly products and they seem good, and want to try it.
Already showed the car to some of my mechanics, they all said engine is in good shape, just the timing belt and timing bearing needs replacement, the coils,plugs, etc is good to go.
I want to use:
Engine Flush Plus
Synthoil High Tech 5W-40
Speed Tec
Fuel System Treatment
Cera Tec
Honda Genuine oil filter.
I may use Zic ATF which is DW-1 or Z-1 which is for my pros tranny, or some compatible ATF Z1/DW-1 from Liqui Moly.
My best guess is that the previous owner used a shitty, maybe a 5W-30 at best, and never changed the ATF since its not Red as its supposed to be. If anyone has used these products, do comment.
