it doesn't effect the suspension just lifts the body off the chassis. import more than likely there not that expensive.
Thanks bro .. will confirm you
Sent from my XT1080 using PW Forums mobile app
Have installed 80 led's bar light .
Now that's how it looks.
SSR has leafs in the rear and torsion bars in front. Torsion bars can be cranked to lift it bit dont over crank. It will effect the ride quality. Leaf spring rear can be lifted. Unfortunately SSR is LN107 and dont come with solid front axle like LN106 so options are limited.
Thanks bro.. can we replace the torsion bar ?to make it work more?
Can we put shackle in leaf spring with 2" longer shocker at rear and 3" longer shocker at front with torsion bar??
Increasing plates in kamaani will also do the job?
Increasing leafs in your leaf-springs is only going to stiffen your already stiff ride. Re-Arching may work for a while but will not give you the flex required in full droop.For front check this video out. https://www.youtube.com/watch?v=1DmnByXE1ycFor Rear install 2 x extended shackles and upgrade all four shocks and there you have a low cost raised rig.Alternately you can get Ironman kit (kit link) which is around 1500$ FOB and will provide around 50mm lift.
@sgk111 but it will only raise it from rear.
Yes, you are right
Have some issue after changing tyres of bigger size my Hilux going to vibrate after going above 70 or 80 .. have done alignment balance and all but can't find it
Have some issue after changing tyres of bigger size my Hilux going to vibrate after going above 70 or 80 .. have done alignment balance and all but can't find it .
Change the tires back to the previous tires to confirm if the problem still exists or the new tires/wheels are shot
check shackles / Leaf Spring bushes and rear shocks absorbers
It's always best to use the factory suggested specs for tyres, which are best for suspensions, ride, tyre life, etc. Never a good idea to use tyres larger or smaller than that which is officially specified by the manufacturer
I want to raise thats why installed it
@offroadstuff thanks, will check it
