Make sure you get the ones from Sher Shah rather than those from the market. The market ones are either local or China made. Very unreliable. The ones in Sher Shah are either Italian or German made.
Also, keep in mind that there are two kinds of switches - a regular one and a reversible one. Both look the same, but the wiring is a bit different. A regular one can only be set one way.
Float DOWN - Switch ON
Float UP - Switch OFF
The reversible one can be set either way - simply by changing the wiring. Which is useful if you want to wire it up so that switch can only go ON if there's enough water in the main tank. You throw in a reverse switch in the main tank and a regular switch in the secondary tank (the one you need to fill). Wire them up appropriately and your motor will only run if the water level in your secondary tank is low AND the water level in your main tank is HIGH. This prevents your motor from burning out running empty when there's no water in the main tank.
