all functions in the cluster will not work.only following may work if your electrician know use of a digital multi meter and know what a pulse means.
RPM, Temp, Gear Position display may work. Odometer in this cluster works through VSS drive pulse from transmission. It is a precision task to configure this cluster , Good Luck
If you are in Karachi Jamshed Road Guddu Electrician can make it 70% functional as mentioned above.
@mir.azam knows the location
