Bcs this purge valve cant be fully controlled by ecu...u can not change vlave setting in ecu
Disconnect only orange wire from purge valve grip coming from ecu.phir us ki jaga body ka earth dedo bas....phir ap log gari chalao us ke baad me proper hal bata dunga InshaAllah
Yar yeh pics kese upload hoti hai batao zara.me pic upload kerta hu
Check in reply section... I am using mobile app..
Sent from my SM-G530H using PW Forums mobile app
What's app me pics.. 03126003531Umair
Btw if the ecu is not providing enough current then you can use a relay to operate the valve
Perfect.. relay is better...Can voltage stabilizer works well?? I have one spare in my yard..
So you are trying to tell that ECU is faulty and that is why those a## holes of 3S are reluctant to rectify this problem because they know that will cost them heck a lot of money? If Cultus purge valve is same, how about swapping that just for testing purpose?
Very good. Just ruin the wiring of brand new car with relays....
When you do this, you are actually bypassing the ECU. It is equal to directly connecting purge hose with throttle. If it opens at 3000 rpm, ECU software needs an upgrade to fix this issue.
If idle was fine and there were no jerks, then just directly connect hose from charcoal canister (black box) to throttle and drive for few days and observe if check engine light appears. Also observe the mileage and check if there is any starting issue. Do not cut paste the genuine wiring or connect any relay or you will simply void the warranty.
Ap log filah bypass kerke chala lo..kuch bhi nahi hota
Sent from my SM-G925F using PW Forums mobile app
Idle pehle uper neeche hoti thi...ab smooth ho gaye hai
Mera nahi khayal ke is se milage me farq parega..sirf gari jerk nahi keregi
Engine light nahi ayegii..meri gari ke Nab sensor me masla tha tab engine light nahi ayi ...purge valve tu phir bhi sensor nahi hai [emoji12]
Yeah well this car already runs fine in winter and in lower temperature in summer. Problem only arises when weather is too hot which results in increased evaporation of fuel in tank and building pressure in it.
Meri gari 13km/L ker rahi hai long me...lakin yeh masla hal hogya hai...hosakta hai ab milaege achi hojaye
Wese hota yeh hai ke jab tanki me evaporation of fuel bantay hai tab yeh valve on hojata hai..lakin mehran me tank me aisi koi cheez nahi jis se ecu ko pata chale ke bhai tank is full of evaporation please open the purge valve...ha ha ha
A Bosch water proof relay with good connections (made with solder and heat shrink tubes) won't ruin the wiring.Infact I would test the voltage before doing anything.
That's not even present in Cultus EFi
