Salam,
Can anyone please guide me where I can buy Nissan NS-2 (CVT Fluid) gear oil?
Regards.
Plaza nissan parts dealer
Brother to the best of my knowledge its not available in whole karachi including plaza, DHA, zamzama etc.
You have to do with Toyota genuine CVT oil in tin box which is 1,200 rupees per litre.
AoA
I think ad van dont have cvt check the dipstick you should use dextron 3 atf fluid recommended for nissan matic j, k, s
Regards
Brother the AD VAN and AD Expert all have conventional auto with torque converter.
Wingroad with 1.5L HR15DE engine with front wheel drive are all CVT and only 4WD are auto.
Not all wingroad are CVT the RS version 2WD is simple auto with hr15de engine,
Plz check dipstick it should be labeled what fluid to use.
Thanks
Does Dextron 3 ATF can also be used for BlueBird Slyphy? Dipstick said Matic-J Fluid.
does dextron 3 atf is applicable for bluebird sylphy? dipstick say that it needs Matic J fluid.
matic J is a bit more friction modified General Motors Dexron III-H, I have used Dexron VI instead of Matic J but its hard to get in Pakistan.
You guys have the liqui moly HFM ATF available though which covers about 30 different types of ATF - and its pretty stout full synthetic base
Overseas motors plaza. They keep genuine Nissan ns2 CVT oil.
