Hi
I have a Nissan Bluebird Slyphy with 1.5 engine I am facing a weird issue maybe it's normal or maybe it indicates a problem don't know.
When I start the car in the morning after some time if I switch on the air conditioner the compressor kicks on instantly along with the fan but the low side pipe remains hot and after sometime like 20/30 secs the car engine gets a little load and it starts cooling the pipe instantly and after that it works normally. The weird thing thing is the clutch is always engaged means it starts as soon as I switch on the ac button and it doesn't trip when engine gets a little load. Secondly after the first start in the morning this cycle doesn't happens all day means after that it works instantly all day. Secondly the clutch is always on it never trips no matter if i set the temp at 25/26 it's always running it never trips. The fans change speed accordingly like at first start they are high but when low side pipe starts cooling it runs at full speed.
I have checked the ac pressure low side high side they are all normal.
Please anyone share their opinions.
