Do you see the air-bag sign in the cluster while you are driving the car with seat belt on?
Did you buy this car recently or this error just started appearing out of nowhere?
If you do not see the air bag sign in cluster, then remove the +ve battery terminal of the battery for 20 minutes and re-connect it. Sometimes it helps to clear the codes.
But after that don’t forget to re-adjust the time, vent direction & air circular mode, but these things will re-set.
