Just empty out the coolant and use Caltex extended life coolant, it comes concentrated so you will need to dilute it with Distilled water / battery water.
Or you could just get the Toyota or Honda pre-diluted coolant if you want to spend a little extra.
Do make sure there isn't a leak or consumption of coolant if it is decreasing significantly over time.
