I Bought my car Nissan dayz 2 days ago 2016 model 59300km done ithe issue is that while driving the car for half an hour the D sign on the dashboard starts to blink
the transmission oil may be low, i suggest please visit a workshop connect scanner and get the service diagnostic data. You may also need to change the transmission fluid at earliest.
others gears are normal when i start the car D stay stable after some drive of 20 30 km it start blinking
means when fluid is warmed up it trigger the alert visit a workshop connect scanner runs diagnostics. Please change the transmission fluid, if never changed since purchase.
issue solved Problem was in the cells installed under the passenger seat i just replaced it and everything works Fine.
Kindly share some.details and location of above cells....I am facing the same issue in Nissan Dayz 2016
