If anyone can help regarding:
White rectangle indicator, above ECO. It appears when i am above 30-40 km/hr and remove my foot from the accelerator.
My Idle Stop indicator keeps on blinking.
The white rectangle sign appears whenever the battery is being charged through regenerative braking.Eco issue blinks when the battery is drained out. (That's how it works in my Alto, i assume it to be the same in your Nissan)
Eco idle*
Do any of them, is a bad sign? because i have heard (only) that idle sign should be stable.
The battery being recharged is a normal phenomena. Rest, the Eco idle light shouldn't blink unless the battery is discharged. Does your Eco idle system work?
sometimes it does, sometimes it doesnt. Havent mastered it yet.
I will get it checked because mine idle sign isn't stable at any time. Its always blinking. may be issue is with the dry battery under the seat.
Eco idle works only if : You've fastened your seat beltYou've pressed the brake pedalThe car is in D or N It will disengage if you: Turn your steering wheelRelease your break pedalOpen your seat beltMove the gear lever from D to R or Parking
Anyone knows ? What does A green circled signal mean ?
I m also facing this issue recently when i have installed a dry battery.....is it normal to have this white rectangular light?
I am also facing this same issue of white rectangular thunder light when i have installed a dry battery in my nissan dayz...so is this normal?
