Here is a better view of the inner guts.....
As mentioned earlier, the beam forming the main support for the fuel tank to sit on is not alligning up. The piece still incorporated with the main body is actually from the post 68 front end (I have to give credit to whoever grafted that on......craftmanship is excellent). A 50s beam does not have the round holes you see......Anyway, as you can see, the two beams are not linning up perfectly as they should.
We had anticipated this to happen before we cut the front off. The small pieces in the body need to be cut off and realligned.....
