Product Description
Working on toyota xli/gli/passo/vitz
Honda city,civic,
Mercedes
To use it on vitz nd on all jdm use hobdrive android app
Only 2 Avalable.
OBDII diagnostic tool bluetooth ELM 327
The Elm327-Bluetooth adapter gives you the opportunity to "spy" on your car wirelessly. Convert your PC, PDA,
Mobile to a diagnostic tool and monitor all critical information of the car?s ECU.
The Elm327-Bluetooth is an adapter that connects to the car?s network and then creates a virtual cable between
the adapter and the PC that it is connected. With the help of various open source application for the Elm327 you
can have a digital gauge or an advanced diagnostic system and a powerful performance measurement toll in your screen.
Features:
bluetooth ELM327 is the newly developed wireless scan tool. It supports all OBD-II protocols
-Works with all OBD-II compliant vehicles
-Wireless (Bluetooth)
-Software included for Palm, PDA
-Software included for Windows PC
-Supports ISO 9141, KWP2000
-Supports SAE J1850
-Supports CAN bus
Specifications:
* Support OBD-II protocols as follows:
* ISO15765-4 (CAN)
* ISO14230-4 (KWP2000)
* ISO9141-2
* J1850 VPW
* J1850 PWM
* Item Size: 8.2 * 4.6 * 2.5cm
* Package Size: 12 * 16.3 * 2.5cm
* Item Weight: 58g
* Package Weight: 68g
Bluetooth ELM 327 Functions:
- Read diagnostic trouble codes,both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
- Clear trouble codes and turn off the MIL ("Check Engine" light)
Display current sensor data, including:
- Engine RPM
- Calculated Load Value
- Coolant Temperature
- Fuel System Status
- Vehicle Speed
- Short Term Fuel Trim
- Long Term Fuel Trim
- Intake Manifold Pressure
- Timing Advance
- Intake Air Temperature
- Air Flow Rate
- Absolute Throttle Position
- Oxygen sensor voltages/associated short term fuel trims
- Fuel System status
- Fuel Pressure
- Many others
Package includes:
One CD software
One Bluetooth ELM327
Torque PRo Paid App
Free software:
1.GM Mode 22 Scan Tool by Terry
2.OBD Gauge for PalmOS and Pocket PC by Dana Peters
3.OBD Logger by Jonathan Senkerik
4.OBD-II ScanMaster by Wladimir Gurskij (ScanMaster 3.52 - local copy)
5.OBD2 Scantool by Ivan Andrewjeski
6.OBDII for ELM322 by David Huffman
7.pyOBD by Donour Sizemore for MacOSX and Linux
8.RDDTC by Pete Calinski
9.Real Scan by Brent Harris
10.ScanTest for Pocket PC by Ivan Ganev aka a-ser
11.wOBD by WDT
PM me For Price
