Product Description
OBDII diagnostic tool bluetooth ELM 327
The Elm327-Bluetooth adapter gives you the opportunity to "spy" on your car wirelessly. Convert your PC, PDA,
Mobile to a diagnostic tool and monitor all critical information of the car?s ECU.
The Elm327-Bluetooth is an adapter that connects to the car?s network and then creates a virtual cable between
the adapter and the PC that it is connected. With the help of various open source application for the Elm327 you
can have a digital gauge or an advanced diagnostic system and a powerful performance measurement toll in your screen.
Features:
bluetooth ELM327 is the newly developed wireless scan tool. It supports all OBD-II protocols
-Works with all OBD-II compliant vehicles
-Wireless (Bluetooth)
-Software included for Palm, PDA
-Software included for Windows PC
-Supports ISO 9141, KWP2000
-Supports SAE J1850
-Supports CAN bus
Specifications:
* Support OBD-II protocols as follows:
* ISO15765-4 (CAN)
* ISO14230-4 (KWP2000)
* ISO9141-2
* J1850 VPW
* J1850 PWM
* Item Size: 8.2 * 4.6 * 2.5cm
* Package Size: 12 * 16.3 * 2.5cm
* Item Weight: 58g
* Package Weight: 68g
Bluetooth ELM 327 Functions:
- Read diagnostic trouble codes,both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database).
- Clear trouble codes and turn off the MIL ("Check Engine" light)
Display current sensor data, including:
- Engine RPM
- Calculated Load Value
- Coolant Temperature
- Fuel System Status
- Vehicle Speed
- Short Term Fuel Trim
- Long Term Fuel Trim
- Intake Manifold Pressure
- Timing Advance
- Intake Air Temperature
- Air Flow Rate
- Absolute Throttle Position
- Oxygen sensor voltages/associated short term fuel trims
- Fuel System status
- Fuel Pressure
- Many others
Package includes:
One CD software
One Bluetooth ELM327
Torque PRo Paid App
