Your mechanic needs to redo the job, applying silicone externally does nothing.
If he used a cork gasket and used silicone anywhere on it, it will leak, cork gaskets are installed with help of some petroleurm jelly only and tightened very slightly.
If a paper gasket was used with silicone it will leak.
Rubber gasket with silicone on straight surfaces will leak too.
