hey guys. in my mehran car oil water get mixed.. i went to mechanic he changed the gasket and water jacket and said to me that you now run it 200km approx. then change the oil .. i do so and then he changed the oil ...but still have a same problem i faced.. please suggest me some thing ..gasket water jacket oil all thing is now changed still oil water mixed and in radiator also i see some oil type think.. waiting 4 ur replies. thanks
Did have everything cleaned out u had the head gasket done.
which city you are located? mate, you need to change your mechanic
flush the cooling/water system completely (if car not overheating or not showing any other signs of blown gasket)
yes he washed it every thing with kerosine oil.. when i drive car nearly 10km then white fo appears at the cap of head but when i drive atleast 35km then only oil appears. but it happens every time.
Did you get the head faced before changing head gasket? It is very important as if the head is warped, the head gasket will never seat properly.
Have the head torqued properly in the correct order of bolts.
The head is not faced properly and gasket is not in its place so water and oil is mixing get it redone again.
thanks for suggestions guys..
