Yep. He said they don't have any plans to launch 10w30.
Mobil 10w40, liqui moly 10w40, Totachi 10w40, Zic 10w40 or Meguin 10w40.I'm currently using zic 10w40. Not satisfied with it but acceleration has gone but milage is unaffected. I want to switch to some other brands.
Then you may look for Fully Synthetic, API SN / SN Plus, ILSAC GF-5 in any of Liqui Moly, Meguin, Amsoil or Totachi (subject to availability here locally).
IMO, it is normal. However, do not let it touch the min. mark and especially, fall below it.
Will 5w30 be safe for my car? I never tried in it.
Yes! IN SHA ALLAH it will be! (provided, your engine health is perfect)
How do I know about my engine health?
I had engine flush done and then poured 5w30 liqui moly, car performance, acceleration and milage has dramatically improved. Alhamdulilah. I believe this will settle my long quest for a better oil that suits my engine. Thank you everyone.
Please go through following links to get idea:
https://itstillruns.com/check-see-engine-healthy-7694098.html and https://www.samarins.com/check/engine.html
Except from oil reduction upto 400ml after 3000km there's nothing i could find. And that according to Honda manual and 3S DEALERS and PW, is normal. Let's see how much it decreases 5w30.
I have Honda city 2015 model and 108000 on ODO now. I don't know that previously which oil was being used but I on purchase used Shell Helix 10W40 only time.But I came to the that 10w40 is too thick for City. Now I want again go to 5W30 but upon acquiring from Honda dealership Sargodha, I came to know that once 10w40 is used then we cannot go back to 5W30.I want to know that can I go back to 5W30 or should I stick to 10w40.Point to remember is that there is no problem with engine and oil level is also same.Any help will be appreciated.
You can go to 10w30 or 5w30 there should be no issue, 10w30 is good can use either PSO or Honda 10w30 both are semi-synthetic
