Dear Pakwheelers,
I Have Jialing Jh70 which is performing very well and good average but i saw today oil seepage/ leakage on specific point of engine area is there any danger sign because i am worried that isnt these are the sign of engine life is over (i mean complete overhauling) or does these 3 bolts have seals that have to be changed
kindly tell me what to do with this issue i want to get rid of oil leakage
Regards
Bhai g engine purana ho jay to aisa karta hay koi masla nahin is ko saf karo aur dakho k dobara kb tak seepagd ati hay
@ArshadXaidi No major issue just the seal shown in red is leaking .. need to get it replaced .. if the oil is not being reduced signaficantly (as it looks in the pic) then no urgency as well
thanks for quick reply whats the role of big nut in this picture can i change it or does it have seal in it?
if i want to change seal of gear seal as shown in red circle does it changed without opening engine how this seal can be changed?
the bigger one looks like the drain nut .. it is also possible that the leather seal of drain nut has given away ...
go to mechanic and show him leakage area .. on a second thought it look like oil spill from drain nut and air pressure has taken it upwards .. not a costly expenditure .. u'll get it replaced in no time
if the oil is not being reduced much then get it changed on next oil change since you'll have to drain oil for the operation and i'm quite certain that it is a drain nut issue .. initially i thought it is a car gear box then i read your post again to know that its a bike ..
just to be sure clean it and see if u get the same pattern back after 3-4 days .. otherwise it is just the footprints of oil outside the nut during oil change
the bigger one is for oil drain and the seal is of shifter lever going into transmission case.. clean the under belly use warm water with liquid soap and brush, wipe clean with rug and leave over night to check actual seepage
as @Naweed: Mentioned its the gear lever seal
others all good, no need to worry.
Replace the seal hardly 45 or 50 rupees.
My CD70 same seal changed this thursday.
don,t mind bro but its time to sell this and buy a good bike
100-200 k kaam k liye bike sale krni parti hai? and how do you know that it is not a good bike? kiun k aik seal leak hai? :S
bhaiya jii thandey ho jao men ney koyi usey gali nhe dai di hai jo aap ko aag lag gye hai > mere kehney ka matlab yeh tha key bike ka engine apni life pori kar chuka hai 11 saal chal gya hai is lye sell kar do aur koyi dosri bike lo baki us ki khud ki marzi jo chahye chalaye
Unhon nay leak ka solution poocha hai. I think hes wise enough to know when to sell his bike
Sent from my LG-F160K using PW Forums mobile app
sir its jialing bike and i love it much more love than gd cg rp gs i hope u understand
Ji bhai inhoon ney solution pocha tha aur men ney inhen suggestion di hai order nhe dya
Sent from my ZTE BLADE III using Tapatalk 2
Bro I like jialing bike more than any chonda but I don't like its engine it is under powered according to bike weight ager mere pass yeh bike hoti to men is key engine ko 125 cc men upgrade karta
sir but i ask in previous thread professional said that upgrade it to maximum 78cm3 i ask them whether i upgrade it to 86cm3 or 97cm3 my friends suggests to change its engine complete rather than go to upgrade its engine i know its under power but its enough for me
the three bolts highlighted by you in pic out of them bigger one is timing chain bolt or mechanic say timing chain adjuster can't say anything confirm there is spring inside that bolt when remove bolt spring comes out well what ever it is regarding your issueand concern may the culprit in only that bolt oil is leaking from it & making dirty other engine bolts too i recommend don't get engine opened may be seal are absolutely fineits only the leakage from bolt go to the mechanic whom you trust most & is honest many mechanics would try to convince you for opening engine by saying chamber seals are broke whole engine needs to be open
