AOA all experts,
I have 2001 Suzuki alto (petrol) 36000 driven , what do you guys recommend as far as the engine oil goes? Thanks in advance.
Regards,
Daud.
means you didnt change the oil so far or what ?
use Havoline Formula as i do have the same alto two i use havoline formula
I did change once with Zic 5w30 without asking anyone so I thought I should ask you guys for a better option.
Thanks Asad bhai,
One more thing I need to know from you is about Air filter , here in Isb I couldn't find the filter that really fits in to the car , found one with alittle bit of difference, so still using that one.
u can use vitz air filter its similar to alto
once i replaced it wid vitz as its wasnt available at that time not it is
Alright , I will try vitz's air filter this time see if it fits well.Thanks
