Hi all PakWheels members, need some advice about best engine choice for old cultus for better fuel consumption.
original engine is not bad for fuel mileage.what happens to your engine?
Old engine needs an over all and it's carburator, so I thought Its time to upgrade its engine. Need some suggestions.
then swap efi engine that came in same chassis.
Yes that's the plan, but I don't know which one will be best in fuel economy after new engine. Current engine gives 12 km/l max.
by efi i mean that came in cultus after 2007, same chassis but efi engine. Same g10b but 4 cylinder. i think so efi gives little more mileage.
It's a good idea but I was thinking about local wagon r 1000cc engine. Would it be easily possible?
no g10b will be. for k10 you need to modify mounts.
only opt for a swap if you know how things work, if you don't and purely have to rely on the mechanic then please mention your city so we can guide you to a reputable mechanic to help you avoid a major mistake
I live in Lahore and once I did a swap in 88 charade with vitz auto engine few years ago, it was a good experience and enjoyed auto shaskay in old car. Now I'm thinking of putting new engine in cultus for better fuel economy and power.
Suzuki 1.3 or 1.5 will be better.More power less load on engine and in return better fuel Economy.
Do you know any person who had done these swap, I mean how much better can fuel average goes, can it cross 18km/l mark, my aim is crossing 18km/L can it be possible?
Not possible. Max 14-15 with better engine.That is only hybrid and 660cc territory.
g16 or g13 or g10 efi ones, whichever you can find for cheap.
How much g16 will cost with auto gearbox complete set. Roughly idea
80-100k..... scrappies have gone nuts. it depends on dumb luck, if you are too lucky might even get it in 60-70.
Can you please recommend someone in Rawalpindi/Islamabad
Efi engine is good option but need also ecu and wiring sensors and may b costly
To swap an efi engine into an old Cultus? Rehman Autos ijp should be choice number 1, but not certain if he would take on the task. Baki dmotorsports in g12 regularly does swaps of all sorts, you can go to him
Okay Thanks.
Yes i want to swap engine into old Cultus, 2004. Body is in good condition.
I also want to make it automatic transmission and power steering, would it be possible ?
