On applying brakes of my car when speed is above 60kmph the front right tire skids but car doesn't stop and all other tires keep moving. Is it air in the lines (needs bleeding) issue or something else?FYI: The car is Mehran 2016
Can be cause by air inside the system, bad proportion valve or bad discs/drums.
Can it be fixed in normal brake service or mechanic should be directed something?
Can be fixed if mechanic know some common stuff. Although you have to explain your problem.
