Unscrew the four screws marked in Red
Then pull out cup holder and remove two screws under it marked in yellow to remove the front cover
Pull out the whole front black panel of dash board and speedometer will be exposed
Unscrew the four screws marked in pink and carefully n slowly pull the speedometer and remove two grips on the back and remove the speedometer.
