Thanks brother for your response,
Today i have replace the crankshaft sensor, since i have mistakenly clear the alarms through OBDII before replacing the sensor so it's unknown whether issue has resolved or not, it will confirm in a day or two when i will drive the car, furthermore i have checked old crankshaft sensor reading with multimeter (in ohms & at diode continuity) it is showing values & that values are also changing while rotating some metal infront of the sensor, which means sensor may was okay
I always keep the fuel up
I only visit when it needs repair,
can you plz confirm the solution of 1750 ? the electrician who changed the crank sensor asked me to change the car gear oil for P1750, i don't think so it will work, as per my knowledge P in the code is indicating power issue
