Hi Everyone,
Can anyone please guide me on the P1399 error code?
After many checkups with the mechanics and electricians, the problem still exists, and the check light always turns on within 10 to 15 minutes even after resetting the error.
Car: Daihatsu Move 2013
Thank you for your valuable suggestion. I didn't check it myself.
Looks like broken wire of egr solenoid or bad grip. Or the solenoid is bad
A.o.k brother your issue is resolved or notSame issue with my move 2013 I check each and everything but problem is not resolvedScanner give code p1399
Can anyone tell me who resolved this issue, I checked egr valve, catyletec converter, spark plugs full tuning, inlet clean throttle etc, but p1399 not resolved, but car is working perfectly, no missing issue in it,
Check fuel pump. And valve lashes.
freeze frame data needs to be analyzed, just random services are not gonna solve the issue
dont you love that!
stop visiting morons because they are "low cost"
Start diagnosis with checking glow plugs.
Finally my p1399 code is removed from move 2013 model, the issue was only in coils, old coils was shorts and installed some other Toyota, although I have no facing missing problem, but ECU detect this issue, when I replace coils original move 660cc p1399 code is clear.
