Of course, I've been looking into it already. The only issue may be actually sourcing the ECU used.
The transmission is the same as the one I have, the 5 speed automatic. I inspected the connector going to the transmission and there are two slots with no wires. I opened up the transmission where the solenoids are and on the inside of the transmission there are two wires going to those same two slots. I'd imagine these are for the up down signal wires for manual shifting.
Looks like i have to run wires from the transmission connector to the ECU and from the ECU to the paddle shifters.
In addition to, I need to replace the gear selector as I don't have the right one, as well as the tachometer.
The only thing I'm wondering, if I source a used ECU with the code on it, would I be able to copy and paste the code into my ECU? Or is that not viable? I am capable of working with code, so the only issue would be limitations on my current ECU.
