There is a wind tunnel at PAC kamra that I know for sure.
Other than that, there are some UAV developing enterprises that probably (though I am not sure) have some facility. Nescom/AWC (air weapons complex) must have one too since they are responsible for the missile development.
All these, however, are military organizations so its pretty unlikely you will be seeing any "links" or "references" except for maybe PAC which is not so secretive as the others.
Added: Just found a link. Its official PAKISTAN YEARBOOK 2004, so its as reliable as it gets.
Wind Tunnels
Here is an interesting read originally from a Chinese Article published in Chinese Aviation Magazine and the Author is a Chinese Test Pilot. Its babel fish translation but still readable. Interesting that he compared thunder 04 with blk 52 ! (early ones not Advanced ones) Interestingly, he also explained 04s fly by wire functionality with details.
"04 JF-17 in the fast changing technology really been fully reflected. This also appears local farm laborers said admiringly its first 03 years. After some mediocre performance of an aircraft packed with high-tech carefully modified, we have clearly started to develop his demeanor, the eyes of the world focused Chengdu, the international community continued to speculate that the level has reached 04 in the end. It has been dealing with the F-16, such as master head in a fight on the strength of the international market? According to the information obtained by the author, with surfers and explore! 1. 1 configuration. side of the JF-17 and 04 F-16 similar to the configuration, Medium used pneumatic normal aspect ratio wing edge of the layout, highlighted the strong performance of low-altitude and high-subsonic mobility.
But in the details, the two were different, the first 04 : JF-17 edge of the area and more than 01 planes. also much higher than the F-16. Aircraft wings are designed to improve the edge of the lift-to-drag ratio under a certain angle of attack, improving the performance of the aircraft at high angles of attack. But using such a large edge design of the aircraft is not, it is estimated that only a F-18E/F. Trouble from the edge of the 5.2 m 2 to 7 m 2, increased by 34%. It will not only raise the maximum lift coefficient aircraft, taking off and landing capabilities. also greatly enhanced the mobility of the aircraft at high angles of attack. extremely powerful vortex edge of the wing airflow postpone the occurrence and development. F-18E/F excellent performance at high angles of attack apparently inseparable from its side of the wing design. Meanwhile, behind the JF-17 04 / end up greatly, bow torque at high angles of attack can provide. while 04 increased their use of the JF-17 High Angle of Attack expected to further enhance mobility! But more important role is that of the JF-17 while 04 will be significantly increased focus on aerodynamic brought forward.
We know that while the focus of the aircraft is located, Lift edge of the vortex caused by the contribution of the wing while washing aerodynamic flow will significantly toward the center. Therefore side of the aircraft configuration is usually static longitudinal instability, active control technology needed to be addressed. For example, the F-16 is a typical "relaxed static stability" with the conventional design : layout, F-16 wings moved forward by 40.6 centimeters, so aerodynamic center forward. M0.9 at its static stability in slightly negative, and 8% at M1.2. Aerodynamic focus toward growing cause of the border, 04 JF-17 center might change (after I speculated that it might be a slight shift : DSI weight because the more obvious the former fuselage, Yields rear edge of the electronic module will be partially offset by the increased weight and nose). 04 JF-17 combination of aerodynamic focus, the focus changes I guess the static stability compared to the earlier 04 JF-17 will be further relaxed. And the use of "the entire longitudinal flight control authority fax + 40 degrees more than two simulated redundancy backup" system will be fully satisfy the static stability After the relaxation of control! JF-17 04 relaxed static stability will not only further enhance their mobility, More importantly, will be greatly reduced in the span of supersonic trim resistance and help span performance of the supersonic, DSI combination of the weight and the weight of the whole growth pushed down, The greatest number may be more than 04 M M1.6 the biggest increase in the original design! Of course, increasing the edge of the edge of the vortex induced intensity can also lead to larger aircraft pitch moment of non-linear problems, Early mechanical-hydraulic control system is obviously not, but for the JF-17 flight control run well in the 04! 2. Details from the wing of the main wings, the JF-17 and 04 F-16 are different. JF-17 04 wing leading-edge sweep angle of 42 °, composite wing bending and torsion, and the latter leading edge sweep angle of 40 °. Aspect ratio of about 3.0, both front and rear wing. F-16 wing no reverse! Contrast can see that the wing leading edge sweep JF-17 04 greater aspect ratio smaller than the root shoot, Airfoil closer delta, in a large range of airfoil stall characteristics, and inter-and supersonic flight resistance small! Is likely to be absorbing the essence of the Russian type pneumatic three generations!
Even more noteworthy is that JF-17 strain J-10 and 04 in the same front wing on the basis of bending and torsion using a composite wing design No composite wing bending and torsion and 16. Why? Design, I believe that this may be related to the airfoil 04 JF-17 is more like a delta wing, delta is the biggest drawback of induced resistance, easy airflow vortex formation, loss of front lift. With the front flap and using composite reversed, can improve the overall speed of the largest lift-to-drag ratio. India's LCA has a similar design, I see in inspection data on the Indian side in the LCA had explained his comments : He said the purpose of this design is used to improve the characteristics of wing lift, as he thought the wing dihedral angles of attack. first stall at high angles of attack, time pressure center moves, bow torque produced, and yet Winglet stall. Therefore horizontal control. That the design can be used to enhance the lateral stability of aircraft at high angles of attack. As we all know, single Yields Yields larger aircraft to fly at high angles of attack is the reason, Yields will be shielded fuselage turbulence lose lateral stability, thereby restricting the mobility single Yields aircraft at high angles of attack. If the speculation is true, then in connection with the design of the JF-17 while 04 will increase their ability to fly at high angles of attack. able to its excellent maneuverability at high angles of attack! Gen will bring slightly smaller than Winglet flutter, usually cut with a sharp or heavy objects to be resolved JF-17 in each Winglet whose missile flight test of time with this estimate, Yields in Canada and the electronic module removed after a sharp cut, although flutter can be resolved, but feel a bit uncomfortable in the number of visual! 3. 04 JF-17 inlet using the DSI Inlet (internally called "shell" inlet ), this inlet many online discussion, the author is no longer in detail, in general terms, are : Compared with the F-16 fixed inlet and improve the gas efficiency reduce the total pressure loss (equivalent to a certain extent, increase engine thrust-weight ratio) and also to simplify the structure, lowering the weight. Performance benefits of stealth aircraft! Second, the engine / thrust-weight ratio in addition to the performance fighter configuration with a great relationship, Engine performance had a great relationship with, for example, the fighter is close to the level of performance and acceleration, not much difference between drag coefficient in the circumstances, greater engine thrust, higher thrust-weight ratio, the greater the aircraft SEP. reach their natural / acceleration more! JF-17 currently used by 04 turbofan engine is Russia's RD-93/RD-33K Engine thrust RD-33 increase of 5% over the entire thrust of 8,300 kilograms of thread, 5,040 kilograms of thrust operations. Pushing for more than 6.62-6.7. CAC learned from the website of the JF-17 01 6,411 kg body weight of the air. normal takeoff thrust-weight ratio of 0.915, more than 200 kg in weight after 04, hold in esteem than the estimated increase (approximately 0.94%), but still did not reach 100. Of course, in the future, promote the use of domestic over 8 WS-13A (Mountains), will enhance the performance of aircraft.
F-16 Block 50/52 and is the latest equipment to enhance thrust Fll0-GE- 129 and Fl00-pW-229 to Fl00-pW-229 example, maximum thrust to 12,890 (daN), in the middle Thrust 7918 (daN) Fl00-pW-220 hold in esteem than the 7.2 to 7.9, good performance. Of course, there has been an increase in the weight of the F-16 Block 50/52 fuselage, the F-7 air-emphasis, 8 to 386 kg, 472 kg (Fl00-pW-229) increased by about 1 ton of weight Although the thrust increased, but rather a piece of hold in esteem the F-115 decline According to information available to 1.05%. Climbing / ****** circled by contrast, we can see that the engine restrictions JF-17-16 04 hold in esteem relatively lower, the situation is not much difference in configuration, air gap between the drag coefficient is the case, according to the formula, we can see SEP. F-16 Block 50/52 and cross-close. M supersonic velocity and maximum performance may be slightly ahead. Circled with the engine thrust-weight ratio and stable performance to a certain extent, Transient stability circled and circled and circled generally consists of the two aircraft have different requirements for stability circled, reduce the height and velocity in the circumstances, in order to pursue the smallest radius circled, Aircraft must satisfy two important conditions that the maximum lift coefficient wing aircraft. relatively high engine thrust-weight. The reason is that the plane circled stability, Thrust = aircraft must meet resistance (gravity combined with lifting the level of solidarity Y), if the aircraft circled the small radius. must be able to weed out the lift, thrust, if not at this time, unable to overcome the large lift-off, the aircraft will not be able to maintain stability will swap high. Similarly, even thrust a great aircraft, but small lift coefficient, can provide a stronger level of cohesion, The plane circled a small radius would not, because the F-16 is a higher thrust-weight ratio and greater lift coefficient. it is very stable circled outstanding, JF-17 04-16 more than the maximum lift coefficient with even a slight advantage, However, the gap may still lead to hold in esteem than their less stable circled on the F-16. And the plane then circled the instantaneous hold in esteem than modest. instantaneous decision circled the main wing aircraft and load the maximum lift coefficient, While hold in esteem than JF-17 and 04 F-16 Block 50/52 of a difference, but in the wing set. 04 JF-17 is obvious advantages, the JF-17 wing area of 24.2 m2. only less than 16 m2 3 Series 27.87 13.53 However, the F-16 Block 50 empty than 2 tons of light, the author projections for a moment. JF-17 air wings which contained about 04 of 380 0.9kg/m 13.53 Early in the F-394 m2 0.9kg/m than lower and the F-16 Block 50 combat wings are projected to be 430 0.9kg/m 13.53 04 JF-17 more than their low! And the instantaneous load-wing aircraft circled closely related to performance, wing lift coefficient in similar circumstances (JF-17-16 should be slightly higher than 04). lower wing loading units under the weight of the wing and circled greater solidarity, the more rapidly changing perspective. Mirage-2000 can achieve the instant spiral angle of 30 degrees with 264 0.9kg/m m2 3/s wing set are inseparable. Although the F-16 also adopted the edge of the wing combination blended wing body design to reduce the wing load, circling high performance. However, it may be inferred that the JF-17 contains 04 low-wing blink disk performance should be even better!
Comprehensive configuration and engine performance, the F-16 configuration is extremely successful, even later become fighters reference design targets, coupled with the strong support of the engine. F-16 air combat performance is extremely fine ;JF-17 configuration and the F-16 is closer to 04. But JF-17 in 04 hours later introduced to absorb the East and West, the three-generation planes aerodynamic design lessons DSI and the combination of new technology, the pneumatic, JF-17 04 16 aerodynamic should be further optimized design based on the results But the F-16 engine with a slight lag, Overall performance of JF-17 flying 04 F-16 should be very close to win! 3. range / JF-17 combat radius CAC website of the biggest turn 01 only 2,037 km range. The 3,000 km with promotional data are not unified, very differently. The former estimate is likely to be a cause of this difference in the situation in which oil was contained inside the range under which data is calculated to bring in three The case reached the drop tank, but the flight of JF-17 with a radius of 04 changes The fuel capacity of more than 200 kg in weight and increase, estimated coefficient of 0.284 containing oil. The increasing number of 0.25 compared with 01 planes, carrying three drop tank has a range of over 3,000 km will be, its combat radius of 1200 km in accordance with its mandate should be between different profiles. Although the flight and combat radius with the F-16 is still lagging behind, it can meet the needs of various operational tasks! Fourth, radar / navigation radar aircraft nose properties of space is very important. MiG-21 nose inlet large size makes it difficult to install the radar antenna, severely limits the ability of the order on the beyond-visual! After the adoption of DSI, 04 fuselage in front of a marked change from 01. pictures can be seen on the 3rd JF-17 airframe parts is the apparent dip, similar V-shaped cross-section. allegedly to pre-compressed air entering the inlet. However, the adoption of DSI, the abolition of this design, from the photos, 04 planes closer to a round cross-section of the fuselage, There are rumors nose radar diameter from 04 to 03 increased the 600MM 660MM. Analysis from the photos seem to be very credible. If the JF-17 04 660MM if the diameter of the nose radar, French Mirage 2000 will be extremely close, French Mirage 2000-5 2000C and the diameter of 674MM/670 RDI/RDY radar MM! JF-17 with a difference of over 10 MM 04, there is no guarantee of space in the nose, What we have to do is to raise the level of production in the design of the radar! F-16Block40/42 groups from the United States began to 50/52 lots APG-68 to improve the equipment of its F-16 (V) 5 radar. The main emphasis of the improvements to enhance the radar-time-between-failures (to 100 hours). while retaining the right to a strong resolution against moving targets on the ground and, Doppler Beam Sharpening ratio of 64:1. According to verify : APG-68 (V) 5 for RCS=3 target detection range as 75 kilometers can be achieved on the level Tracking distance of 45 km. Good performance, but acknowledged radar device to a level slightly lower than the Mirage 2000-5! In 2000 and after, The new edition has started to change F-16Block50/52 APG-68 (V) 9 radar. APG-68 further improve its performance compared to the earlier, a 30% increase from the space probe. RCS=3 target detection range estimate of more than 100 kilometers, and the integration of SAR, Airborne Early 10 times faster than the computer! This is not equipped with radar but F-16Block50/52, mainly for export to Turkey. Greek Air Force F-16 and the Israeli escalation plan "thunderstorms"!
In the 1980s, China began to make contact with the West advanced radar and fire control systems "model for peace" project, Americans got a taste of China's strength in multifunction radar system. APG-66 understanding of the radar systems, which were reflected in the integrated thinking and then contact the radar for the European and Israeli-made advanced radar developed later, we have laid a solid foundation. 04 JF-17 radar program to be elected, Early concerns over the Italian FIAR Grifo sp radar. Pakistan is a series of radar Grifo traditional users, the introduction of the production line and is widely used in the F--7P. F -7PG other aircraft. Grifo-7 radar performance Yes, maximum detection distance conjecture before inferred (RCS=5) 38-40km distance tracking, which can simultaneously track 10 targets (TWS. Tracking side scan format) and the two hit the target! Meanwhile, Locally Israel Herta and French Thomson company (the validity) provided adapted from a Mirage 2000-5 R DY radar from the RC-400 and EL/M-2032, the same outstanding performance. But with the PD-made multi-purpose radar to participate in competition and the unexpected situation, Domestic PD radar because of the advantages of performance and compatibility, Pakistan finally accepted our radar system plan. We recommend what radar can defeat many of the foreign experts in radar? Data show that domestic flight 607 was developed PD radar, which is launched from the air intercept. close combat fighting, and sea attacks, aided navigation and other functions. Clutter can be a serious under the circumstances, as provided under the effective launch capability. This radar is high, a variety of low-frequency waveforms and waveform adaptive pulse compression and adaptive management. Tracking the edge scanning function tracking 10 targets from 40. OTH also can be controlled missile attack in which two of the two, The radar target of a typical fighter (radar reflectivity cross-sectional area of 3 square meters) found that a distance of more than 75 km. Under distance of more than 45 kilometers, a distance of more than 135 km off target discovery. IFF devices and radar cross-linking and modular design, and have a good electronic countermeasure capability. Although the information given is not very detailed, and also confirmed that it can be seen that JF-17 in this radar equipment, Early F-16Block50/52 achieve its overall performance level! In addition to the radar, I was most interested in the use of highly integrated 04 JF-17 "centralized distributed" navigation framework We know that the structural development of avionic system has gone through a separation ceremony, the joint ceremony and the highly integrated four stages : the first generation of integrated avionics system for discrete structures, radar, communications, mutually exclusive navigation equipment have their own independent antennas, RF front-end processors and monitors. using point-to-point links. Second-generation avionics system for joint architecture use several low-bandwidth data processor to complete the exchange of data transmission functions, such as navigation and weapon delivery, store management, control, the number of bus diplomacy between the modules together through sharing resources and the control of the backend only show in the information chain link.
The link between the equipment simplified to reduce the volume and weight of the system. Comprehensive processing and display control of the mission to resolve the problem of integrated avionics system has played a significant role in promoting the function and performance of aircraft a step forward, and F-15, F-16, F /A-18 universal application. Integrated Avionics took third structure, based on the "treasure pillar" of the F-22 program for 1974. Further improve the overall level of this structure. Its main technical characteristics are shared with the integrated core processor system (ICP) to complete almost all of the signal and data Department Jimmy, ranging from display and control system integrated onto data processing. The structure features is the integrated core processor integrated fire control, navigation and computing and management, cockpit display graphics, Store management, system management tasks, such as monitoring the system intact, scheduling and task management. Call integrated core processor modules different functions at different stages of implementation. Fourth, took the highly integrated avionics structure, based on "platform gemstones," Joint Strike Fighter (JSF) as its representative, To meet future war fighter was developed by the high-tech indicators Integrated Avionics Architecture. In the field of RF and optoelectronic two widely used modular, and can change the design outfield, a comprehensive aircraft skin sensors. RF integrated functions, and put into practice. Many of radar, communications, electronic warfare functions from hardware configuration gone, the acquisition of these functions entirely through software. According to the "International Air" on the 2004-11 period, we know that, "JF-17" aircraft in the air -- subsystem in the current third-generation avionics system on the basis of joint steps to achieve a higher level of aggregation. Avionics System mainly through its two mutually redundant MIL-STD-1553B of the various subsystems and equipment Bank link Two interchangeable parts which weapons task management computer (WMMC) as "JF-17" aircraft control and management system -- Jimmy the core, using the PPC processor, running the system operational flight software (OFP) procedures. complete the task management and navigation systems manipulation and Fire Control Solution, store management, comprehensive information, display control, Alarm voice, data transmission and other tasks. We know that through understanding, "JF-17" is still based on MIL-STD-1553B data bus network. In data processing and transmission speed, data fusion with a large gap between the F-22, The overall design of the second generation have been far greater than in the structure of the joint concept. Integrated Avionics structure and third-generation concept very similar. So that the design meets the standard in Europe, "the two wind" standard is no exaggeration! And the task of modular processing system (MMC), it was not until August 01, began to experiment. Most F-16Block50/52 before the show or HUD computer control / fire control handle dollars Computer / center for the three sets of computer interface modules independent storage management system for a typical two-generation framework "JF-17" (WMMC) are very different. Even the latest installment of F-16Block60. its mandate with significant control computer or separate from the computer, information integration remains limited. The use of advanced integrated avionics system, which will greatly reduce the burden on the pilot in a future war. raise its key issues of judgment and the judgment of speed and enhance the combat effectiveness of fighter!
With Advanced Medium Range Air-to-Air missile missiles and infrared imaging fighting growing popularity it is necessary to stress that under the JF-17 "04's electronic warfare system, according to information. its radar warning receiver (RWR) and missile approach warning (MAW), with Chaff injected with infrared devices (CFD), and electronic warfare device components. specific properties are advanced. But T that is the most salable, "JF-17" Yields on the 04-built response initiative jamming aircraft Directional interfere with the sophisticated technology used to detect the exact position of power will be concentrated at the threat of interference radiation source This system may disrupt a class of advanced AIM-120 air-to-air missile radar seeker, while also confront the fighters and targeting radar locked onto. Reportedly, Chengdu Aircraft Design of the electronic warfare system designed mainly focused on the future combat environment, Pakistan in particular targets users of the Indian Air Force are equipped to face the large number of R-77 missiles. and the ability of the aircraft in India is not available in the basic, Pakistan does not have access to the F-16. I believe this system could directly from J11. 5. , the stealth / low detectability is no doubt that JF-17 04 this point certainly prevail, In addition to DSI is important to help improve the performance of the Stealth, the F-16 is more than a piece of the compact is one of the reasons for their appearance. Although the JF-17 04 F-35 did not achieve all like stealth, but with the help of RAM coating, With its appearance advantage of JF-17 04 can greatly reduce the adversary's radar detection range. offset opponent on the radar performance advantages. In circumstances similar to radar performance. JF-17 04 enemy can be done entirely found that enemy positions. with low detectability of the JF-17 in the order on the beyond-visual (BVRAC) is a huge advantage! 6. 04 JF-17 is used as the weapon system MIL-STD-1760 bus, it PL-9C SD-10 and domestic use in the circumstances, can also use a variety of other weapons, Interestingly, South Africa, Pakistan, which is based on research R-Darter H-4 in the range of 120 kilometers. active radar homing also reported good performance, taking into account the relationship between Pakistan and South Africa. Daniel and South African companies in the development of various precision strike weapons on the strength and the JF-17 configuration can be made with the forward-looking infrared and infrared search and track (IRST) system and, therefore, The JF-17 should not be exported only after there is a lack of precision weapons to attack the problem! As for flight control. Cabin - level, there are many pictures online information, I will not repeat in! In a very short time, CAC To meet the changing market environment. come up with the rapid-Block50 significance lies in the level reached F-16 Block50 less than half the price, which is the domestic market or the international market. will have a major impact! "
JF-17 Thunder Multirole Fighter [Thread 3]
There is a myth that JF-17 is a copy of MiG-33 or LFI, well for once and all this myth is being busted, hopefully no one in future will come up with this absurd claim:
MiG-LFI [I-2000, Light Tactical Fighter Project]
The Russian air force has been left behind in their research and development due to the economic problems, which they faced after the fall of the Soviet Union. But after more than a decade the Russian air force is willing to make the state-of-the-art fifth generation fighter. This is obviously a response to the JSF project currently being tested by the US. The fifth generation fighter can accelerate the Russian airforce which currently operate on aircraft which were developed in the 1980s' to a technological breakthrough. For years the US had been using stealth technology in their bombers and now has finished the testing of their F-22, which is regarded as the worlds most advanced fighter. The aim of the fifth generation project by the Russians is to make a fighter which is better than the F-22 and as advanced as the JSF. The success of this project would not only enable Russia to have a strategic balance over US weapon systems but also make a lot of money from their arms buyers. Russia can look forward to orders from countries which buy Russian weapons especially India which is the largest buyer of arms from Russia.
The design features are still unclear as the assembly of the prototype has not commenced yet. The code name of the latest Mikhoyan Gurevich fighter is LFI. The aim of this project is to make a lightweight multi role stealth fighter. This information comes with the official announcement of the Russian Airforce of its priority to build a lightweight multi-role fighter. This is being done to oppose the heavy weight fighters like the MiG-MFI and the S-37. The possible competitor of the MiG-LFI project of the S-54 which is being developed by the Sukhoi OKB.
Overview of the MiG-LFI Project
According to the defense weekly. The development of the Logkiy Frontovi Istrebilte project was aimed at producing a fighter which is capable of satisfying the requirements of the Russian Airforce for the next 10-15 years. The project is revealed to the defense weekly as I-2000 which means Istrebitel 2000 (fighter 2000). The project is believed to enter service by 2005 as the frontline strike fighter for the soviet air force. This project is also likely to be a major component of Russia's arms export. The revealed information about the I-2000 suggests that it is likely to be an archrival of the JSF of the US. The I-2000 is also revealed to be capable of both air-to-air as well as air-to-surface operations.
This project is a part of a long line of lightweight fighter projects by the MiG aircraft industry. The other lightweight projects include the MiG-21 and the MiG-15. The I-2000 is believed to be shorter than the MiG-21 by up to 1.3 m but is broader than it by about 4.5 m. the I-2000 is considerably smaller than its predecessor the MiG-29.
Design
The I-2000 is designed to have a reduced IR and Radar signature. This gives the aircraft the stealth capabilities. The I-2000 is also believed to be very light ,manoeuverable and with short take off and landing capabilities. The I-2000 has a blended fuselage and a thick wing center-section. The aerodynamic configuration of the I-2000 is considered to be very unusual and is equipped with powerful thrust vectoring system thus providing the aircraft with unimaginable agility. The landing gear of the I-2000 is specially designed so as to allow landing approaches at high angle of attacks.
The pilot and the and the WSO (Weapon Systems Operator) share the cockpit in tandem. The presence of a WSO improves the effectivity of the MiG-31 as the WSO is entirely dedicated to radar operations and weapons deployment. This decreases the workload of the pilot and increases efficiency.
Engine
The engine required for the I-2000 are currently not available in Russia. This means that the Russian scientists are working on a revolutionary new engine, which can be compared to that of the one used in the F-22 or the JSF. There are reports from official sources that the LFI project includes a single and a twin engine version.
The LFI is expected to be sold to countries which are heavily dependant on Russia for arms. This include India and China. India had recently bought a version of the Su-30 which is known as the Su-30MKI which was developed specifically for the requirements of the Indian Air Force(IAF). This plane is compared to the Su-37 is many respects and is better than the other versions of the Su-30. The Indian has signed a deal with the Russians to help them in the complete development of the S-37 which also means that the MiG-LFI projects will also be entertained.
Had an interesting conversation with a friend who is a Flt Lieutenant regarding the jf-17...
Even the first lot of 42 aircraft will have a decent amount of carbon composites
It is compatible with J-10's dual racks and can be fitted if required
Dual racks can be used for Air-Air and Air-ground munition
Wingtip hardpoint can carry a medium range BVR missile
No plans for CFT for thunders so far
Undisclosed AESA radar from both China and West is under evaluation
Not all thunders will be equipped with AESA
The Chinese radar has very good performance in all parameters and is a robust sensor
SD-10A is a serious contender along with a western one
Weapon trials are almost over and IFR will be applied from the first squadron onwards
Precision guidance is achieved with the help of Atlis and Chinese pods in both day and night strikes
The PAF pilots are volunteering more and more to switch to thunder rather than any other aircraft in inventory
Two 32 bit powerful weapon and mission management computers
Systems approach applied throughout the project which includes engine, avionics, EW, fuel capacity etc
Complete EW suite with active defense capability including SE-2 MAWS (this is a fact)
RCS is lower than the F-7 series which has lower RCS than the Falcon (block 15)
APU for power backup
Complete HUMS for aircraft integrity
