salam brothers, i have 1st generation 3 door pajero. The problem i m facing is that both the clutch cylinder kits keep failing and leaking oil which renders the vehicle useless and constantly pushes me to check the clutch oil... Please if anyone has the solution let me know..
I had this problem once my clutch oil went down to the point where I had no clutch but after rebuilt of master cylinder with new seals it worked like charm again never had issues afterward new seals are very easily available as shezore have same master cylinder
thanks alot for replying sir. actually i have changed the kits 3 times now and i have got the cylinder polished once as it had some roughness in it which destroyed rubber part of the kits, but now today, again this has happened.
Change master cylinder than
will it be available new or used? and is any other cylinder compatible with pajero's?
In my case it used to be slave clutch cylinder... Japanese new part is available for around 3600rs something... I didn't know that and suffered lot. But you can now buy that and you are good to go. Plus keep an extra set of kits in your car. Clutch cylinder van seriously f*** up at worst of times...
thanks for the reply, can you please tell me the name of company which makes Japanese parts?
Sorry i dont know that.
It's available in the market brand new and you can easily find the difference in Japanese and Chinese version. In had the gen1 pajero and faced the same issue many times.. just change the master cylinder and the salve ..and it will be alright .
