I bought Pajero 2001 DID. While converting to 4H, the indicating lights in speedometers responds accordingly. But when I switch to 4HLc/4LLc, the lights of central differential lock/rear differential lock give no response. Is there a way to check whether the sbove 4wd options are working? Any insights from an experienced fellow?
Are you sure that they aren't fused bulbs?
Sir I will get bulbs checked first and then I will update
I own a Pajero third generation, 2001 model, DID 3200.
I am facing a problem, jeep is stuck in Second Gear and not shifting to Gear 1 or 3. Please guide what is the possible issue and how to fix it.
It is the gear controller. You have to repair or replace it. Which city are you in?
Thank you for your kind input. Based on your guidance, Gearbox was checked and a grip was found detached. It is fixed today.
