aoa i want to swap my g674 3.5 gdi with a new engine but i need some help and guide which engine can you guys recommend it has to be bolt on no alterations
i was thinking g674 mivac which comes with pajero evolution or g674 dohc
So did you end up swapping the engine after all?
If yes, what was your final choice?How was the experience?How did the car engage with the donor engine?
Well it went very well i ended up swaping with 6g74 3.5 dohc with manual transmission now and everything is working well so far first few days after swap was hell becuse of wiring and ecu it wasnt running as it should a/c was not working during driving engine stalled ....then i changed the wiring harness and ecu a couple of times with different ones from other 6g74 engines and finaly they matched with the engine and now its working perfectly with manual its giving better avg then auto transmission .
