Which dealership?
Bro if u go for 165-70r13 u will lower ur car will start touching when loaded with friends or family. So the exact hieght is important which could be attained with 175-70r13 tyre size.
Your dealership is misguiding you. Engine Oil, Oil Filter and transmission oil are changed on 2nd free service @ 5000 KMs running. Even then spark plugs are not changed.
Change your dealership to some better one.
I changed spark plugs at 20,000 KMs.
AOA ! I need to know as i own wagon R 2014 and it has accelerator cable. Does new models of wagon R comes with throttle sensor? Does it effects car performance?
Khair Agencies on super highway karachi
Which dealership is better???
It must be 36psi for stock tyres. Also try to shift between 2-2.5k rpm to improve fuel economy
The jackrod is not properly placed in trunk otherwise nothing must vibrate.
Astagfirullah! Nothing must be replaced on first service (1k). They looted you bro
Change engine oil, oil filter, and gear oil on 5k service.Better read owner's manual for details
Yes new WR is having Drive by Wire system (electronic) since 2016 onwards models.No major effect on performance, just having slightly less pick / agility against the one having accelerator cable which is more agile and may be having better fuel average (but it can be achieved or ruined as per driving style & other factors on any of the version.
Bro I am from Islamabad so cant guide you about Karachi. Any other member from Karachi to help??
Many thanks bro. I also felt lesser pick of new cultus comparing wagon r 14 model. I hope this will improve fuel avg.
What is the stock tyre size?
I am sorry but I also got my car from Kher agencies and I got my 1000 km and 5000 km derives done from them. Only routine check up on 1000 km and oil changes at 5 k .. No spark plug changes. I don't know whom advised you about it
اسلام علیکم ورحمۃ اللہ آپ سب کو۔۔۔میری گاڑی کی آمد 31 مئی کو متوقع ہے، کیا گاڑی ٹائم پر مل جائے گی یا لیٹ ہوگی ڈلیوری؟
WagonR has apparently become the top seller for Suzuki thanks to Uber and Careem , I believe. I booked in early April and was told that my car would be delivered in 3 months. However, when I got my booking number I was told that the current waiting time is 150 days and the car would be delivered by 28 August!
I booked early March and the date given is 18 June
145-80r13
@snakelegnd 80 percent of 145 is 116 while 70 percent of 165 is 115.5 so i think it will no cause serious ground clearance issue. What is your take on this?
This will help you in accurate calculations
https://www.miata.net/garage/tirecalc.html
