The alloy wheels in the so called face-lift “spy shots” of Pak Suzuki Wagon R VXL are identical to the one in the below YouTube video about minor upgrade of Indonesian Karimun Wagon R last year. Check out the alloy wheels at 0:35 with the Suzuki logo in the middle. The review is based on the AGS transmission GL model with rear chrome trim.
I've suzuki wagonR and it is around 100km on the odo. I'm experiencing some rattling sound 'ttrrrr...' coming from the left side of dashboard on bumpy roads. Any idea to get rid of it?
Your car is in warranty go and check it from dealership.they will fix it.
This wagonr gl variant doesn't get abs..but single airbag is there.
Owner Review for WagonRhttps://www.youtube.com/edit?o=U&video_id=219JiqzHSes
WagonR owner ReviewSubscribe to my channel for more such videos
bhai no video on this channel what to subscribe ???
Any body have aome experience about usage of OBD2 connector and OBD scanning tool with WagonR PKDM please share the details
only OBD2 scanner which support (CAN) works with suzuki cars.
when buying OBD2 Scanner make sure it supports (CAN) closed area network.
@hash737 thabks buddy for guidelines Have u ever used it what kind of information it gives to us can you please explain ? Soecially woth reapect to Wagon R
I have heard ECU is locked by Suzuki and can only be accessible by any 3S dealer. By passing it will void the warranty.
Chinese OBD2 Bluetooth scanner worked with Pak Suzuki.
But only apps that found working for Android are
SZViewer and HobDrive
I am using this for Swift
@mohsan87 Thanks buddy can you please guide from where i cab buy this ?
You can order it online from AliExpress
How did u get HobDrive to work with Swift? I tried but it couldn't connect with the ECU. What settings did u use?
Select kwp protocol
I loaded the template for Suzuki Liana for this, it already had KWP protocol selected. Looks like there is some issue with the port in that car then.
I used following to connect to swift.
Thanks, the car I was testing on was a friend's and not my own, so didn't experiment much. Will try these settings next time.
