Hi I'm from Peshawar and recently I bought a PKDM Alto VXR which was swapped with following:
Engine - K6A engine
Gear - 4speed automatic transmission
ECU / Computer - E2 (33920 75HK0)
Car use to run very sluggish. Did the usual like cleaned throttle body, plugs, injectors, air filter, used profikar engine flush and 10w-30 mobil oil. Acceleration somewhat improved but it still runs sluggish with AC. Fuel consumption with AC is 6.2km/Litre which is alarmingly high. The 02 sensor was also cleansed however the dholki it screws into was without a filter / jaali. Now I'm not sure if there's any filter present by default and what its function is.
I took the car to few mechanics/ electrician and none gave a convincing answer. So here I am looking for any leads or help that anyone can give as this was bought to be driven in city but its becoming a burden due to its fuel consumption.
