Passo 2016, total 106k km driven now.
Have been having issues since the last 2 months.
Eco Idle does not work now.
Fuel average has also dropped to 12-14km/l from 22-26 initially.
Since the last 2 weeks, the car has been taking a longer time to start up, but this issue only pops up sometimes. Sometimes the car starts up just fine.
I've taken it to Toyota Defense, KHI, where they said it was a battery problem and it needed replacement. But replacing the battery didn't solve any of these issues.
I then took it to a local mechanic where he cleaned up the spark plugs and throttle body. The result was that acceleration improved slightly, but Eco Idle, crank, fuel average issues persist. He thinks it is a failing fuel pump.
Kindly help, I'm lost.
If it helps, 5w30 engine oil, replaced every 5000km, other oils are fine. Tyres are standard.
