Hi guys. My issue is as mentioned above.
I'll give you some background first. The problem first occurred when I
had the front wheel bearing changed. The ABS light turned on and the D
light started blinking. Turned out the mechanic had put the bearing
inside out and changing that fixed the problem. Fast forward to now (a
month later) and the ABS light turned on and the D light started
blinking, I checked ABS and it wasn't working. I switched off the car
and then switched it on and the ABS light was gone and D stopped
blinking, checked ABS by braking hard and it worked fine. So that's the
story. I don't know if the two are related or not, I don't know much
about cars.
