Aoa ive just bought a new Passo 2014 eco idle model few days ago from Car Markaz dealer G-8 Markaz Islamabad ... M observing a very strange sound from the front wind screen, its like when i drive the car through concrete road or any other imbalance road, a stutter sound came from windscreen and all of a sudden its vanished whenever i hold up the screen !! M really worried now ??Can someone help me in this scenario!!! M assuming perhaps its some interior plastic touching through the screen or do i need to worry about that because its a new car and m assuming that most probably its screen haven't been replaced before !!
First mistake, buying a car from a dealer. I just hope and pray that you checked & verified the auction sheet of the car instead of just relying on what the dealer said.Please share auction sheet of the car and its pictures so the Pakwheels community can help.
check by holding the plastics of dashboard that are in contact with screen.
-if there is some sound of plastic, check if it is out of place or not.-check after washing the car(for example) if there is any water inside the car around the windscreen or not (this way you may have a guess if itts windscreen is replaced and properly not fitted.
Yes i checked it through auction sheet as well as i verified it from my denter and painter !! Its all ok !! Ill go again for this sound to my mechanic to verify the problem !!Probably its just plastic contacting the windscreen !! M hoping all will be well IN SHA ALLAH !!
Yes bro i washed it on regular basis and also drives it in rain ... No water incoming ... So one thing is confirmed that windscreen has never been replaced ..
try tapping the plastics on pillarsthey are on clips.might be loose or unbalanced
Not confirmed only by this, it can be.
But leave this for now if it has been replaced or not.
YOu can check all the plastics, their clips and padding.
Ys sure i will IA do it!
Hey guys i would like to add one important thing to my thread that the sound came after the jerk that ive came across when i was traveling to shahdara garden because the track was under construction .. One my colleague said it might occur because of that jerk !! Any suggestions?
Anything can be possible,closely check the edges of the windscreen, there might be some crack etc. or something unusual.
