Bros,
I am using Passo 2010 since November 2010, I am getting following error:
P2239 OBD-II Trouble Code: O2 Sensor Positive Current Control Circuit High Bank 1 Sensor 1
I have cleared the error so many times through OBD scanner and also clean the Sensor 1 and Sensor 2, also I have changed CAT two months ago as no CAT was installed the fuel economy slightly increased after installing the CAT, I have also observed that instead of CAT 2 on the lower side there is Dholki installed.
Whenever I fill the fuel tank the average reset to 18 km/l and even 20 km/l but whenever I speed up the car and to 90 km or more then 90 km the ECO light gets off and never switch back ON again, if i scan the error through OBD I get the above error.
Can someone help me out to tell me a good mechanic who can resolve my issue and who knows how to remove the error using scanner . The issue is that I get an average of 14 km/l in local with speed of 70 - 90 km and 12 km/l on long at the speed of 110 km.
Kindly suggest mechanic in ISB
