Salam Pakwheelrs hope you are all good...I want to change lights of meter from stock yellow to White ..Is it possible? Is it hectic process or only require changing of bulbs..I have attched pictures of meter
If the numbers on the dials have been painted yellow, there's nothing much you can do about it. If not, you can change the bulbs to LED's
No i dont think its painted yellow... but one thing i have figured out as the meter color is white .so white bulb may rise the issue of visibilty...
I don't think so. You can replace the bulb with LED'S and see. If there are any issues, you can go back to stock bulbs.
You can always go for bluish white, or extreme bright LED then they will be distinguishable
