AOA pakwheelers.....I just bought passo racy.......its an awesome car with grt response.......fuel average is btw 12 to 14 kmpl in city n long routes......want to change transmission oil.......need help in actual quantity required for Passo Racy 1.3.......
i use ZIC A+ 5w30 in my RACY. it takes about 3.5 liters. mine is 1.0
Is it a CVT or conventional automatic?
Dear thanx for the concern........i replaced transmission oil 2 days back........its not CVT.........conventional 4AT.......Used PROFICAR's ATF.......
Dear mine is 1.3.........after opening the chamber n filter total of 2.5 litres oil was there........so i also poured the same 2.5 litres quantity.......it guage shows 2mm below MAX level.........so Passo 1.3 requires max 2.5 litres of Transmission oil.......Reconfirm my statement from original owner manual n drain out the extra oil........my brother changed ATF in his Toyota Premio 2006........that took 3.5 litres.......
Conventional 4AT........
Brother 5w40 was not Transmission oil vicosity grade, it for Engine oil..Transmission oil is thick somwhere 20w plus...I have also Black passo Racy 1.0 n got similar fuel average of 12 n 15 and surprised for 1.3L giving same average...
Dear i replaced transmission oil last day after 12000km as oil seemed a bit dirty........This time it took 2.8 Litres........will have to check from owners manual.........While my 1.3 consumes arround 3.2ltrs of Engine oil with new filter showing oil upto the top mark of guage.......for the last two times i m using 5-40 Proficar.........
Dear i got max fuel economy of 15.6 kmpl..........and it must get to 16+ on motorway not getting over 100 kmph of speed........My car showed continuously 17.2kmpl average for almost 25 mins on starting journey on motorway from lahore to pesh........but its really hard for me to drive in such a slow speed........I usually drives btw 120 n 130 kmph on motorway during day........while during night driving my normal speed is around 140 kmph........
