My passo do vibration when get to the speed of 20 and goes to 50 km/h and after that disappears but it also disappears when I leave the accelerator
bad inner axles...(gearbox side)
Solution?
Replace inner axcels
every time at this speed or sometimes it does and sometimes it doesnt?there is an old post of someone with same issue and he tried many things and failed
Yes Everytime it's does at this speed
Yesterday I have check the both inner axel through mechanic and he said both the axels are okay even he Cross check the axel but still having issue
Did he opened them ? Or just looked through under side.
sir @pwuser16965899274 how good are your tyres ? in terms of kms ? check the manufacturing date over tyres -----> please replace if more then 3 years old.
The problem with my Passo is finally diagnosis and the issues was a callorations because due to excel work the collaboration was out and giving me the issues so finally I have scan it through scanner and the problem was solved
