Salam All;
What should be the hi-octane/patrol ratio for Civic Reborn? I am using 30/70;
Regards,
Well regularly i also use 30:70 ratio on all the cars...but nowadays the petrol is toooo dirty so em using almost 80% hi octane...
30 being patrol.... right?
Nooo, I meant as in hi octane being 30 and petrol 70.But that's when we are receiving fairly clean petrol..Nowadays petrol situation is too bad...So using ratio hi octane : petrol80 : 20
thanks!
@fahadkhlilSalam Use 50:50 hi-octan and petrol
10:30 is ideal. But these days im using pure e-10 full tanks.
edit, and ya the fuel quality is realy bad these days, we dont even smell petrol now it smells real bad.
Chinyoti, What kinda mileage do you get with the e-10?
its normal as i was getting before around 350+- kms on 35 liters. A.c is always on with me driving usualy its on idleing on a.c aswell around 10 km.L
then you're pretty lucky to have e-10 there...hows the performance? changed or still same?...
y where do u live dont you have e10 there? i felt e10s performance tobe better.
Quality of fuel improved since couple of years so there for 50:50 is ok
I live in a country with clean petrol So I usually go for high octane at the next fill up.
I use 100% hi octane. The higher the ratio of hi-octane, the better.
^theres no benefit of doing so, just increasing ur expences.
salaam:
well if money is not an issue then go for high-octane every time you have to fill her up. no need for any mixing circus!
regards
I asked honda engineer about it and he recommended 1/3 hi-octane and 2/3 regular fuel to be good. I personally prefer and have got better results with 50:50
Your statement couldn't be more further from the truth. In my cultus, I could feel significant difference between hi-octane and petrol. The most visible difference was in engine knocking which reduced considerably. The acceleration also improved. Even now when sometimes I get it filled with petrol, the degradation in performance is clearly there
30/70 is ok
@chinyoti; nopes we dont have e-10 in sialkot.
