this more likely to be true. i had been using Performa, on a trusted retailers recommendation and was quite satisfied with it.
however after 5, 6 months now (this Feb, 15) i found total garbage and sludge kind of stuff in the bottom of the can.
this means, this is adulterated, / and may very well be packed locally
stick to caltex, or zic or shell or Carient, and if your vehicle requires use Mobil from a trusted retailer after verifying the box code if possible.
also note that PSO carient has the code verification process to check the counterfeit ... this means when you buy a PSO oil you can check that it is genuine by scratching and sending a code to a sms service.
DO NOT USE PERFORMA
eddy,
LAHORE PAKISTAN
