Has any one taken Cultus 2006 with 2 to 3 adults till khunjrab via babusar. If yes then how was the performance of Cultus. I intend to go on excursion trip after Eid. Should I take risk going there in Cultus.
If its suspension, tires and engine is good (no heat up issues) then you can easily go on Cultus, I went on a 2015 Cultus form Lahore to Khunjrab all the way from KKH as babusar top was closed
It depends on mechanical condition of your cultus if it is good than you can go, last year I went to Shougran , Naran on my Cultus 2005 with 4 adult and three kids, you can read my thread:
My friends have went to khunjerab pass on mehran. So cultus should do it if it's maintained properly. Check engine oil, gear oil, coolant and clutch plates before going.
if mechanically fit it can go easily as 660 cc cars also reach there
